- iOS 18.3
- obisidian 1.8.4
- I’m typing in Hangul (Korean) and letters are disappearing.
- Something is twisted when erasing the letters.
- If you type the letters slowly, you seem to be fine.
- English and numbers are fine.
Does it happen if you use Gboard instead of Samsung board?
I’m using a third-party keyboard called Dankey and Slyder. I am not experiencing any issues using the default Apple keyboard.
I don’t think we are gonna attempt to support those third party keyboard. With 1.8.4, we are experiencing problem with Samsung keyboard on the Android side. Perhaps your problem is connected.
Hopefully this bug will be fixed.
are those the same bug of your or different?
Whether it’s the same or different, it’s clear that there’s a problem with Korean input, and it’s been a bug for a long time and hasn’t been fixed.
Ok, I am gonna to close this and please follow the other two bug reports you linked.
