Keyboard shortcut: switch between split panels
I have a two panel split.
I would like to keyboard navigate from one panel to the other.
I can’t find an entry for this in the “Hotkeys” section.
I had a shortcut setup for this before upgrading to version 16.x.x. It seems to be gone now.
https://cdn.zappy.app/6eada257815dccd6edc509785c2c7bf8.jpeg
Add option to set keyboard shortcut in the hotkeys section.
I just click instead of using a keyboard shortcut.
Just so you know, there are already existing “focus on tab group to the (left/right/above/below)” commands you can assign hotkeys to.
IMO, This plugin is bettet and simpler.
Actually, that plugin does not do what this feature request is asking for: it cycles through tabs, not tab groups, as it has not been updated to work with Obsidian 0.16 yet.
I would really like this as well. Yes, I can focus on the tab group to left/right/above/below, but then I have to have 4 hotkeys. All I really need is one - to cycle between them. I don’t normally have more than 2, and I just want to be able to easily bounce back and forth between them. I’ve checked out several plugins, but have yet to find one that can do this.
