Disclaimer
Community Directory: Keep Sorted
I have a lot of notes that are basically lists: plants in the yard, vendors, glossaries. I got tired of putting new items in the right place by hand, so I wrote a plugin that does it.
Wrap a list in markers:
%% keep-sorted start %%
- Dog
- Cat
- Bird
%% keep-sorted end %%
and it stays sorted. Sorting happens after the note has gone five seconds without changes, so lines don’t jump around while you type.
A few details:
- It sorts by the text you see, ignoring list markers, link syntax and formatting, so
[[file|Display]]sorts as “Display.” - Multi-line items (indented continuation lines) move as a unit.
- Tables work too; the header rows stay on top.
- Options on the start marker:
order=desc,case=no,numeric=yes(so 2 comes before 10), andskip_linesto pin lines at the top or bottom. - Commands: mark the current selection, or re-sort every block in the vault.
The markers and options come from Google’s keep-sorted tool for code, so if you already use that, the syntax will be familiar.
Install it from Community plugins (search “Keep Sorted”). Source and issues: GitHub - rtm/obsidian-keep-sorted: An Obsidian plug-in to keep lines in a code block sorted · GitHub
Feedback and bug reports welcome.
