Using the Kanban Plugin, is there a way to make it so that when you move a card from one list to another, the corresponding note is moved from one folder to another in my vault?
Specifically, when I move a card from the Ideas list to the Posts In Progress list, I want the corresponding note to move from the Ideas folder to the Posts in Progress folder in my vault. And, eventually when I move that card from the Posts In Progress list to the Archives list, I want the note to be automatically moved into the Archives folder.
Is there a way to do this automatically or do I just need to drag the notes into the respective folders after I do it on the Kanban board?
Thanks in advance … I hope this isn’t too stupid of a question
