Hello Emile!
here is an update, I tried to install python right form the download link you provided, now this is what I see when opening a shell and searching for pip3:
~ which pip3
/Library/Frameworks/Python.framework/Versions/3.9/bin/pip3
but still got this error as before:
Error: Command failed: pip3 install --upgrade semantic-markdown-converter --no-warn-script-location --user
/bin/sh: pip3: command not found
Maybe there should be some way to get things working in a way that I ignore?
Thank you again! (and happy new year!)
Dan
Hi Dan! Happy new year :slight_smile: it might be that python isn’t properly added to PATH. Did you enable that setting during installation of python?
Btw, here is an extended installation guide I’ve been working on: https://publish.obsidian.md/semantic-obsidian/Installation+of+Neo4j+Graph+View+Plugin It shows how to make sure it’s added to PATH during installation
Better documentation is now available at https://publish.obsidian.md/semantic-obsidian/Neo4j+Graph+View+Plugin! It gives details on usage and installation of the plugin.
The new version 0.2.3 is now also available, which adds a nice context menu and automatically updates the graph with changes you make.
I’ve also created a Discord community for those who need help or are interested in discussing and developing new features: https://discord.gg/sAmSGpaPgM
Hi Emile,
I was able to install your plugin on Windows 10 pc but I failed few times until I finally did it. I suggest to split topics about installation issues for Windows and Linux versions.
Second, I don’t get it if it is possible to use it as static graph and be able to open it in the same state when I close Obsidian.
My use case: I have a software product which I want to describe in Node1. Then I have 4 child nodes for CRUD: Create node (how to create object in software), Read node (how to read properties of the object), Update node (how to change properties of the object) and obviously Delete node (how to delete the object). Let say in Create node I have 3 different methods to create it, the rest of nodes also have some brunches which are connected together to one node (let say) Integration node.
I want a graph which will keep a layout which I create. There is no point to randomly show me the nodes especially if I don’t see hierarchy.
Am I able to do this? I try to organize nodes but they move only horizontally. For some reason I have to click on every text file in order to see it as a node in the graph.
Is it any limitations in Neo4j or it is possible to implement but it will take some time?
I see this request for graph functionality for ages on this forum but it looks like nobody cares which in my opinion will be a huge step forward in development of software.
Thanks
Hi Alex, thank you for trying out the plugin! I’m copying this message from Discord.
Windows is indeed a bit harder to install. The next thing I’ll work on is to remove the Python dependency. Do you think this will help?
2: This is currently not yet possible. Saving the state of the graph is something I have to implement! (I should document that, actually).
Do you have Hierarchical Layout on in the settings? Without the Hierarchical layout, you should be able to organize the graph layout. But you cannot ‘lock’ a node into place yet. (I’ve also just added this to the roadmap!)
You can expand the neighbourhood of nodes by double-clicking on them. Or you can select multiple nodes, and then expand all of them. See https://publish.obsidian.md/semantic-obsidian/Using+the+Neo4j+Graph+View#Interacting%20with%20the%20graph
No limitation here! I’m pretty sure it should all be possible :slight_smile: And also very useful and general features, so I’ll definitely do them at some point.
Thanks for the input, it’s valuable to hear what people are missing most in the plugin.
Integrating Neo4j relationship types would be massive.
Hi all!
I’ve been working on rewriting this plugin with the new name Juggl. It no longer requires Neo4j and Python, and has a lot more features than Neo4j graph view.
It’s in a pretty good state, and I’ve been testing it already with some people in my Discord.
I’d highly appreciate anyone who would also like to help test! If that’s you, you can join this Discord: https://discord.gg/sAmSGpaPgM
Heya. Was just trying your plugin. I realised that it wasn’t what I was looking for, but it kinda glitched. I still have the option to “Open in Neo4j Graph View”. I tried reinstalling and uninstalling the plugin again, but it just made a second “Open in Neo4j Graph View” option. Any advice on removing that option? Pasted image 20210322132859
Strange. That should be removed if you turn off the plugin and restart Obsidian.
Hi Emile,
In addition to a typed/labeled link syntax within Markdown body, could you please also consider leveraging the structured data (or metadata) within the YAML frontmatter ?
To clarify: I am not suggesting to use any link syntax in the YAML block. Imho, we don’t need any (when dealing with YAML).
Instead, we can just Treat all YAML scalars as potential link targets.
The linked feature-request explains the idea in detail (with examples) and reflects my secret wish for Obsedian to serve as a poor-man’s graph database (or at least plain-text data-entry tool for one), with semantic links implicitly emerging from structured (YAML) data.
Tabulo[n]
Hi Tabulo,
I think we already spoke on the Discord, but this is possible in Juggl! See YAML Styling
Hi all! Juggl, the new graph view that will replace the Neo4j Graph View Plugin, can now be installed. It will be on the community plugin store soon :slight_smile:
Check out the main body post for more info: Juggl (RC1): A completely interactive, stylable and expandable graph view plugin!
First off, i am super impressed with what seems to be possible. I tested it and one thing immidiatly caught my attention - the graph seems to be supposed to work with file numbers under 250.
I could open my around 500 notes with it, but (as expected) it was quite slow and not really navigatable.
Is this supposed to only be used on local graphs?
Or are there plans to make this useable on higher note numbers aswell later?
Yes. Right now this plugin is indeed focused on the local graph, and the global graph is only provided as a convenience option for people with smaller graphs.
I might look into it more in the future, but it will never be as quick as Obsidians (super fast!) graph view. So it’s a tradeoff between amount of features/complexity of styling and speed here. For more info, see Global Graph mode
I’m very happy to announce that the Juggl plugin is released!
It is a graph view with many new features:
  • Complete control over the style of your graph using CSS, YAML and a new Style Pane.
    • Include images!
  • A new mode that lets you build your graph with all nodes that are relevant to your current project
    • Selectively browse and hide nodes, and pin their location so you never lose them
    • Write new ideas and see your graph evolve
    • Save your graph and continue working on it later
  • 4 different layouts to get unique insights
  • A code fence that displays the graph within Obsidian notes
  • Link type support to label edges
  • No need to install Python or Neo4j
  • Extendable through other plugins
  • Works on mobile!
This is… amazing! :clap: :slightly_smiling_face:
I haven’t played much with it yet but it looks like it’s able to bring Obsidian to a new level !
Thanks for developing this :smiley: :pray: :+1:
Great, I think this makes it possible to visualize the self-organization and order of notes. It is worth exploring.
Thank you for your work :+1:
hi, guys! Do you know how to open Style Pane in Obsidian Mobile? I can’t find the option.
I hope this helps. Check out the right sidebar, then click back (<- Backlinks for …)
