Hello everyone,
About custom JSON in Obsidian
if I been informed correctly, the Obsidian Developers say, that they tolerate JSON as a value in Frontmatter Properties is but it’s not recommendend. But the App don’t support an access to custom JSONs to work with notes yet, which is a very big goal for me :). In the future it will be possible hopefully and they will create a Core Plugin for it.
What could be possible work for now
I’m imagin, if I write plenty of lines of JSON Code as a value in a Frontmatter Property of a Note, could the value as a JSON Data processed by dataviewjs to get a data result which would be display in a Note, where the dataviewjs Codeblock is in?
Frontmatter
json: {
"foo": "bar",
"tok": "qax"
Why I ask
I have a bunch of notes with have the same frontmatter structure (e.g. Link in Detail in a single Note). It would be easier that I could replace the structure of notes with only one JSON.
I’m just thinking how JSON proccessing with Dataview Plugin could work without any other custom plugins.
nothing yet
Best regards,
MB
