What is the difference? Which one to use when? thx
Dataviewjs is an extension (within Daraview) allowing you to use the extensive Dataview library, and execute javascript in that context.
And I reckon JS engine is “just” giving you access to javascript, and possibly various other ways of executing said javascript code. (Disclaimer: I’ve not used this plugin for a while)
(For the latter; If you’d like to you could access parts of the Dataview through accessing the api’s plugin list… )
