Create a note, use callout with code block, type ` 3 times and an issue occurs in the auto-completion of the code block. There is no
>on the left side of the 3 `.
If the code block has
<>, it will cause a rendering error.
If use
\to escape, it may look normal in edit mode, but in preview mode the code block does not recognize the escape character\and displays\, even though the rendering is no longer incorrect.
Yes, I created a new repository without any community plugins enabled and still repeated the above issue.
Obsidian version: v1.5.11
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.4.0: Fri Mar 15 00:12:41 PDT 2024; root:xnu-10063.101.17~1/RELEASE_ARM64_T8103 23.4.0
I noticed that some blocks of code can be loaded correctly in the callout, so I presume that Obsidian wants to be as compatible as possible with this situation, so I’m reporting this issue.
