Hello there,
I want to use the pandoc-plugin to simplify my workflow. Mainly converting MD into PDF through LaTex.
If I run the plugin on a basic MD file (consider a file with just a single sentence without any syntactical structure, just plain text) with the following extra pandoc arguments
–citeproc
–bibliography “/home/username/my_library.bib”
it gives to me
Pandoc export failed: File “/home/username/my_library.bib” not found in resource path.
What does resource path is by default? Why it doesn’t see my bibtex file even if I specified the whole path?
In addition, even I remove all the extra pandoc arguments and it returns to me
Pandoc export failed: pdflatex not found. Please select a different --pdf-engine or install pdflatex.
Despite this pdf latex is correctly installed on my machine because if I run pandoc in the terminal it works properly and I have specified the path to pdlatex into the PDFLaTeX path setting. I set it as the output the terminal command
whereis pdflatex
Why it doesn’t work? Even on basic MD files?
