Is there a way to underline text?
I’ve searched the help files for markdown syntax and there doesn’t seem to be a way to underline text. If that’s true, is there another way I can fairly easily do it, say with minimal HTLM? (I know very little HTML). TIA!
Try <u>|</u>. Replace the pipe character with your word(s).
u can explore this plugin
or this one (but this require you to download manually or using BRAT)
I’m obliged to point out that in text you expect other people to read on a computer, underlining text is bad because underlines mean links.
Obviously in your private notes you can underline whatever the heck you want :grinning:
That worked! I was trying
    . Thanks!
