Is there a way to quickly edit/delete backlink display name?
This is just an example, I have several of these in different note where I want to edit/delete the display name (I think that’s what it’s called, name after the “|”). Is there a way / maybe pluggin for it?
“Alias” edit: my bad. Seems like it’s called “link display text” now. But I would also search “alias” if you are looking for plugins to do things like that.
Isn’t alias part of property?
Is it also called alias?
Hi.
Either link-display text or alias, depending on how the link was created.
If I needed to change the same text in multiple notes, I would use VS Code to search and replace across the whole vault or a selected part of it.
Oh yes, you’re right. I think my knowledge is out of date. Before the “alias” property was added, I think the vertical bar was what we called aliases. I think..? My bad.
So much going on in Obsidian it is hard to keep up. :melting_face:
