Is there a way to put a blank panel on my right sidebar?
I would like to display the local graph on the right sidebar, but it’s not practical if it’s all long and takes up the entire thing. Can I put a blank thing in the sidebar under it so it becomes a square graph?
Nothing showed up in a google search and forum.
On desktop, if you grab (long-click) the tab and start moving it around, you’ll see drop zones where you can drop. Give that a try.
Obsidian_ZRTD0fSyJ7
That seems to work, but ideally I’d want it to be just the graph and nothing else. Do you know if that’s possible?
No blanks.
Just try to endure a sidebar section with a Backlink, etc. icon above or below your graph.
