I have tried searching in the obsidian forum and using duckduckgo, but I am not sure that I have the correct terminology to do an effective search. I can probably make it work by creating a template and assigning a hotkey to that template, but I thought there might be simpler, less bodgy way.
All I would like to do is that whenever I am editing a note and I hit cmd+M
the editor places #mines
where the cursor is. Bonus points if I can do this without using Templates or another plugin.
