There is a problem with the style of the code block and the list together in Source Mode, the indentation is not aligned. And the block always comes with an indent style.
Is it possible to turn off styling in Source Mode? The existing styling issue is better than no styling and just displaying as text.
Does anyone else have this confusion?
Use the ob default theme.
The left side is source mode, the right side is reading view.
- the indent lines don’t line up,
- the red boxes are all at the same indent level, but the edit mode renders in a style that makes it impossible to write at all.
This is the effect of other editors, source mode without rendering styles is more suitable for editorial work,
The line breaks in this code block are also confusing
What fonts are you using for Source Mode and reading view?
I think I solved the problem.
Now I am using the Inconsolata font and using the following css.
/* list Indent */
.mod-cm6 .HyperMD-list-line.cm-line {
padding-top: var(--list-spacing);
padding-bottom: var(--list-spacing);
text-indent: 0 !important;
padding-inline-start: 0 !important;
/* quote Indent */
.mod-cm6 .HyperMD-quote.cm-line {
/* codeblock Indent */
.markdown-source-view.mod-cm6 .cm-line.HyperMD-codeblock {
padding-left: 0;
color: var(--code-normal);
/* all source mode font */
/* .markdown-source-view {
font-family: var(--font-text);
font-size: var(--font-text-size);
/* codeblock font */
.cm-s-obsidian .HyperMD-codeblock {
font-family: var(--font-monospace);
/* inline-code font */
.cm-s-obsidian span.cm-inline-code {
background-color: var(--code-background);
vertical-align: baseline;
/* ident line position */
.markdown-source-view.mod-cm6 .cm-indent::before {
content: "\200B";
display: block;
width: 0;
border-right: var(--indentation-guide-width) solid
var(--indentation-guide-color);
color: transparent;
position: absolute;
top: 0;
bottom: 0;
transform: none;
The indentation of the list and code block is now correct.
