Hi,
When I create a link to a page and then start typing an alias a display text box pops up. For example if I have a note “Metric Space” and I type [[Metric Space|]] when I put the pipe | a display text box pops up and as I write “metric space” it shows the “metric space” as I type it.
Is there a way to disable this box? I see nothing in the settings.
If need be I will write a plugin to disable it but I am not sure the name of the object.
I hate it as because I see no upside to it and the downside is that some of my keyboard shortcuts are disabled when the box shows until I hit return on my keyboard. This makes it the singular place in Obsidian where I have to type differently than anywhere else and as I am often typing without looking at Obsidian it throws me off.
Thanks!
