You can’t render markdown inside a block of HTML. The exception is inline HTML: <span style="align: center"> should work.
However, the better solution would be to add a CSS snippet for the links you want. You can add a class: MOC attribute to the YAML metadata any given MOC notes, then do something like:
Question about the second solution with the .moc internal link - I do have links to other MOCs in the MOCs, but the centering I was trying to do is in a regular note that links back to the relevant MOC[s].
Kind of like a breadcrumb trail, or just jumps to other relevant content. So the navigational links I am trying to center would maybe be in a daily note, or ZK note, or lit note. Would the CSS snippet work in this case? Also, how would I specify this in my note?
Here is an example:
type: Daily
tags: #daily #dailynote #2021 #may #wed
# 2021-06-03
[[000 Master Index]] ○○○ [[100 Personal Index]] ○○○ [[200 Daily Index]] <==Would like to center this
![[🎯 TODO]]
![[🎉 Scheduled Time Off#2021 TIME OFF]]
It’s mostly an aesthetic thing, so not super important I guess, but I would like to be able to do it.
When @ryanjamurphy suggests the class: MOC that is a suggestion for a class name, not the ‘real’ MOC (you just need to find a name not incompatible with existing ones, e.g. center-menu).
