I’m starting to use tags and a nice to have would be a place to keep a paragraph descriptor for each tag. Does this exist already?
In my opinion, if a tag needs a paragraph to describe it, then it isn’t a tag, and perhaps links would be better, which can have a file and description behind it if you want.
Well you ask if this exists. You could simply create a note called “Tag Glossary” and just write out definitions for all your tags.
If you are building up a system, it would make sense to document that system. I keep such notes in a folder called “meta”, or SOPs, etc.
It doesn’t have to be more complex than that.
