I’m trying to create a table (with days of the week) with JavaScript and HTML that takes tasks from a different file-note, and formats them into separate cells (only if the task date coincides with the day of the column). Then, using a button, I change the displayed elements in the table.
I tried using Buttons + Dataview + Templater.
With buttons i call a Templater command that switches a variable in the current note (0 and 1), this variable is then read in a function called by a Dataviewjs block which format the given tasks in a html table.
Are there any alternatives?
Idk if my method is unnecessarily complex but it works fine.
