Hello,
one thing that keeps me from using Obsidian is the fact that each note needs to have a title and if it doesn’t it goes by “Untitled”.
I would like to get rid of the title concept altogether and instead use the first line of the text as file name. Similarly how for example Sublime Text does it.
In the “appearance” settings you can turn off “show inline title” which allows you to visually remove the header, and the plugin above can help remove the need to ever update the title yourself.
Every file requires some sort of title, but this would allow you to hide it and forget that it exists
