Is it possible for templater to auto-generate a block id for a list or task item
I am using dataview to query tasks or lists according to fields generated by embeding template file at the end of the item. It is very useful if templater can auto-generate block Id so In the dataview query I can build link to the items.
Maybe templater has got a solution already
I didn’t find the solution
You can use this plugin: GitHub - adziok/obsidian-incremental-id
I think this fulfils what you want.
works, thank you.
I’ve not looked into that other plugin, but a blockId is just a “random” collection of alphanumeric characters, so you’re free to generate these as you like from within Templater or through other means of generating your text.
See Internal links - Obsidian Help near the end for a little more on the syntax of these ids.
