I can’t really show it yet and have it make much sense. It is really just a bunch of inspirations and ideas I have collected that I am trying to weave into all aspects of all decisions I am making in these early design stages of my 3d short. I want there to be continuity and organization as everything is fit into the story. And, most importantly I want all this work I have done to be easily accessible, without getting in the way, keeping the spotlight on what I am building, not from what I am building it.
I have realized that I am actually best off using both vaults semi-simultaneously. The original vault comes with the ability to jump around with speed and only see the content of each atomic note and the composites of those notes. However the building of new structure gets lost as it it integrated into this already complex system. My focus should be on looking how I am putting the pieces together, not all the pieces.
So, once I have a general direction with an idea construction in the original vault, I can copy that note filled with hierarchical lists of links with added commentary over to my second vault which only has the one central node, which is basically all things from original vault viewed in many different ways. Some of my other posts, I kind of described my process as I did it.
Anyways, in the second vault, I can begin building out much more finalized ideas in isolation but with the support of the structure already being there to guide me (in reference and assisted link creation, etc). As this progresses, I will still be able to use the central node for exploration, but its links will be windows from from the past into the project of the present, which will hopefully be helpful.
I can’t be sure how things will go, but so far so good. Worst comes to worst, I wasted time, but learned something, which is a paradox. Thanks for your curiosity. I will have something share eventually.
