Internal Links with Alias not working inside tables
Just create a new note ‘Test.md’ with this content:
# Test
[[Test]]
[[Test|Alias]]
| Table |
| [[Test]] |
| [[Test|Alias]] |
Both links should be working correctly.
The link with Alias is broken.
  • Operating system: Linux Mint
  • Debug info:
    Obsidian version: v0.15.9
    Installer version: v0.15.9
    Operating system: #72~18.04.1-Ubuntu SMP Fri Jan 15 14:06:34 UTC 2021 5.4.0-64-generic
    Live preview: off
    Legacy editor: off
    Snippets enabled: 1
This is not a bug.
Put a \ before the |within the link - otherwise it is interpreted as being the end of the table cell (which then breaks the table as the number of cells per line don’t correspond anymore).
[[Test\|Alias]]
It’s also mentioned in the docs at the end of the table section.
https://help.obsidian.md/How+to/Format+your+notes#Tables
Moved into “Help”
