I have been using obsidian without a fault for over a year, but recently I am experiencing an issue with opening links. Firstly, I am unable to open links simply by clicking. Only Ctrl + click works. Secondly, when I do use this alternative method to open a link a new note is opened saying “no file is open”. The really weird thing about this is that I can open a note normally and without an issue when I first launch obsidian, but then all subsequent opening of internal links follow the same issue outlined above. Any help would be amazing.
Does the same behavior happen after you have disabled any community plugins that you are using and then restarted Obsidian?
The issue with internal links when in read mode no longer appears after disabling the annotator plugin.
