(Internal Links) A Way To Find The Right Note Quickly When Using Double Square Brackets
My goal is to be able to just type some keywords so that the note that I’m thinking of pops up. Where do I want to be able to do just that? Inside the double square brackets!
Now, the thing is that Obsidian allows me to use a variety of search fields and sub-windows within its program to find a note. For example the search (Ctrl+Shift+F) or Quick Switcher (Ctrl+O). What I actually want to do is obviously not only to find a note, but also to USE a note, which means that I want to link & display the note inside the one I’m working on. So I want to use the double square brackets and I want to make it very easy for me. The situation is the following: When I type “[[ ]]” a list appears with all the notes whose names correspond to the words I type inside these brackets. But this feature of “search” so to say has the same issue as the features I’ve mentioned above: They can only find notes based on their names. As I said before, I want to make it very easy for me to use ther notes for internal linking. In other words: I don’t want to have to remember the name of the note! I use sort of a nomenclature for my notes so I don’t have to bother naming them. Now I’m looking for a way to either change Obsidian’s search function (which I imagine is complicated or impossible) or to create a pool of keywords somewhere within my notes that can somehow be captured by the square bracket “search” function.
Aliases: I am actually able to type an alias of a note inside the double square brackets and the note shows up, but I can not just dump a bunch of aliases one after the other. It seems to work only with one alias at the time. That leads to the problem that the bracket-preview shows me a list of 30 notes. Still too complicated. (I also believe that I am misusing the actual purpose of the alias function.)
Tags: The possibilities that tags offer me are limited because spaces cannot be used. Above all, the square brackets cannot give me any suggestions as soon as I type “#”.
That leaves me with … ?
How do I manage my Obsidian-notes so that I can just type two open brackets and then bunch of keywords I remember from the note I have in mind and after a while hit enter, when only one or two notes are left in the preview?
I hope I can get help from a few experts here, that would make me very happy and would certainly also help some other people who, like me, want to set up a workflow that suits us lazy people. Maybe I’m overlooking a function that is actually obvious - that could also be the case.
Best regards and thank you in advance
Luram
