Installer Not Doing Anything
Hi there! I am trying to install Obsidian and the installer doesn’t do anything. I just downloaded the latest installer for Windows, 1.10.6, and I’m on Windows 11. I double click the installer and the little blue wheel around the mouse spins for a second, then stops, and then nothing happens. Same deal if I run it as an admin.
I checked if it was being blocked by antivirus, ran the .exe as an admin, and restarted my computer and redownloaded the installer but nothing happens. Even in task manager, nothing regarding obsidian shows up.
Any help would be appreciated :slight_smile:
Check your Event Logs.
Event Viewer → Windows Logs → Application
You should see errors regarding the installer crashing, that will give you somewhere to start.
