When starting Obsidian V 1.11.4 no longer auto-creates the Daily Note for me. I have tried uninstalling and reinstalling to no avail.
Just to be sure, as the daily note auto-creation setting was moved (iirc
In Obsidian’s settings, under Files and links, did you select the Daily note option in the Default file to open dropdown ?
@DrSirius Can you kindly repost this and make sure you read and follow the BR template? Thanks.
Moved to this thread to help
Can confirm I’m also seeing the same issue on 1.11.4
@phoenixinter what are you seeing exactly I don’t understand and how do your settings look like?
Continue here: Daily Notes not created when startup
