Insert link into unique note for imported files
When importing a file on mobile, you are given some additional follow up options after the import is complete: “Done”, inserting a link to the file in the current note, or inserting a link into the daily note (if the core plugin is enabled). However, there is no option to insert a link into a new unique note (when enabled).
An option to insert a link into a new unique note (when the plugin is enabled), exactly as with the others
