Input methods are interrupted on desktop when typed immediately after links
  1. Put an external link in the editor such as [link](https://obsidian.md)
  2. Put the cursor immediately after the link, noticed that the cursor may be placed between the closing bracket and the link icon. (It is sometimes after, but that doesn’t really change the result.)
  3. Try to type any content using input method, such as in Chinese or Japanese.
Did you read and follow the Troubleshooting Guide ? [Yes/No] Yes
The input should not be interrupted, and all characters typed should be in composition state.
The first character is always interrupted, and goes out of composition immediately. The composition starts from the second character typed.
	Obsidian version: 1.14.4
	Installer version: 1.14.4
	Operating system: Darwin Kernel Version 27.0.0: Tue Aug 11 21:20:40 PDT 2026; root:xnu-13432.1.9~1/RELEASE_ARM64_T6020 27.0.0
This debug info is from macOS, but this also happens on Ubuntu. And it happens for both Chinese and Japanese input methods.
Seems similar to this report:
