- On a first note to be linked, write a header with a LaTex inline expression.
Example:# Test header $X_i$ - On a second note, create an internal link leading to the header of the first note.
Example:[[Note 1#Test header $X_i$]] - Hover the link with the mouse and hold CTRL to display the preview popup and see the result.
Yes
The math notation to be properly rendered inside the popup preview.
The title with the math expression is only displaying the raw text instead of the rendered math notation inside the link preview popup.
Debug info
Obsidian version: v1.7.7
Installer version: v1.4.16
Operating system: Windows 10 Pro 10.0.22631
Snippets enabled: 2
Plugins installed: 11
Plugins enabled: 7
1: Calendar v1.5.10
2: Dataview v0.5.67
3: Templater v2.9.1
4: Admonition v10.3.2
5: Advanced Tables v0.22.1
6: Linter v1.27.1
7: Excalidraw v2.6.7
- The problem happens for every heading levels
- Only the linked heading is affected. Every children headings on the preview will display properly their math notations.
- Embedded internal heading link displays properly the math notation of the heading.
- Previewing an internal link of a complete files display properly every math notation for headings present on the note.
