With the Settings/Editor/Behavior/Auto-pair Markdown syntax enabled, starting inline code in a document does not automatically add the ending backtick character similar to ‘*’ emphasis or how double or single quotes work with the Auto-Pair Brackets setting enabled.
Did you follow the troubleshooting guide? [Y/N] Yes
After entering a backtick `, I expect a closing backtick to be inserted after the cursor similar to other paired markdown.
The ending backtick is not entered and the entire paragraph becomes inline-code formatted text which is quite distracting.
Obsidian version: 1.12.4
Installer version: 1.10.6
Base theme: light
Snippets enabled: 1
