In obsidian on android, open an existing unopened vault which has both community plugins and some content, so that both the “Indexing Content” toast and the “Do you trust the authors of this vault?” prompt appear on first open.
Observe that the “Indexing Content” toast is shown in exactly the place where the Buttons for the Trust Vault prompt are, completely blocking them until the Indexing is complete.
Does not apply to sandbox vault due to requirement of existing untrusted vault with content to index. No themes. Trying without community plugins does not apply due to needing the “Untrusted Vault” pop-up which I believe isn’t shown with no plugins in the vault(?)
Expected Result
There should be some way to resolve the Trust Vault prompt while indexing is still ongoing. Ideas would be making the Indexing pop-up collapse if tapped, or making the Trust Vault pop-up scrollable in this case.
It is not possible to click Trust/Don’t Trust on the prompt until indexing is done and the toast disappears, forcing the user to wait.
Operating system: android 13 (Xiaomi 2201116SG)
Obsidian version: 1.8.10 (197)
API version: v1.8.10
Plugins installed: 9
Plugins enabled: 4
1: Code Editor Shortcuts v1.14.0
2: Excalidraw v2.13.0
3: Omnisearch v1.27.1
4: Text Extractor v0.6.0
After waiting for indexing to finish:
