Indenting with 2 spaces in 1.8.x
  • Open Sandbox Vault in version 1.8.x
  • In settings, change:
    • turn off “Indent using tabs”
    • set “Indent visual width” to 2
  • Create a list with an indented item
  • Check the number of spaces in the markdown file
yes
I’d expect to be able to indent lists using 2 spaces, as it is currently possible in Obsidian 1.7 (using the setting “Tab indent size”).
The lists are indented with 4 spaces, independently of the “Indent visual width” setting.
Obsidian version: v1.8.2
Installer version: v1.7.7
Catalyst license: supporter
Insider build toggle: on
I understand that the new setting “Indent visual width” is meant to be visual only.
But it would be great to keep the ability to indent with 2 spaces, maybe by preserving the old “Tab indent size” setting in case “Indent using tabs” is turned off?
Thank you for opening the feature requests and pointing to the current limitation related to delimiter based indentation.
Indeed I have the “Show indentation guides” disabled in 1.7 due to issues with 2 spaces indentation.
I’m considering migrating to 4 spaces indentation. In case this can help someone, here’s a way to convert indentation using markdownlint-cli2 tool:
Create a .markdownlint-cli2.jsonc configuration in your vault with something like:
  "config": {
    "default": false,  // Disable all rules
    "MD007": {
      // Spaces for indent
      "indent": 4,
Run the markdown conversion with:
markdownlint-cli2 '**/*.md' --fix
Make sure to backup first. The conversion might not be perfect, and you may have to adjust the result.
