I just want to make use of bullet poitns inside the indent, I’m using the indent to collapse just that section
I’ve already tried the 3 types of bullet points but non of them work, not even on reading mode
edit mode
reading mode
List items (bullet points) can only be indented under other list items. Indenting any other text marks it as a code block.
So if you change that first line to a list item it will work.
Or, since you’re just trying to enable folding, you could change the first line to a heading and leave the list unindented.
system
Closed
3
