Incorrect vim-mode replace
  1. Activate vim mode in the Editor preferences.
  2. Type **bold** on a line.
  3. Keep the cursor on the line, in normal mode.
  4. Try to remove all stars with the command :s/\*//g.
Did you follow the troubleshooting guide? Yes (observed in the Sandbox vault).
In vim, the above removes all stars (as expected from the “global” flag /g).
In Obsidian, only the first star is removed from each group, and we get *bold*.
Obsidian version: v1.5.3
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.3.0: Wed Dec 20 21:30:27 PST 2023; root:xnu-10002.81.5~7/RELEASE_ARM64_T8103 23.3.0
Plugins installed: 1
Plugins enabled: 1
1: Various Complements v8.3.2
I checked on CodeMirror that their vim editor works correctly, and it does (both with their version 5 and their version 6): this appears to be an Obsidian specific bug.
Does it happen in source mode?
Does it happen here?
Thank you for your followup.
The same problem also appears in source mode (the result is *bold*).
The problem is also present in the online editor you pointed to (which produces *bold* too).
Now, vim on macOS correctly produces bold, instead (as does the CodeMirror 5 online editor, again).
Thanks
Please, search/open a bug report here and explain them how to reproduce the bug in their sandbox.
Thanks for the pointers.
Done!
For reference:
  1. This was fixed upstream in the codemirror-vim repo on 2024-11-06.
  2. The fix is apparently not yet included in Obsidian 1.7.7, as codemirror-vim was only updated in Obsidian before 2024-10-16 (Obsidian 1.7.4).
Keeping my fingers crossed for the fix to work in a future version of Obsidian!
I’m running into this issue as well. It seems like the fix is included in codemirror-vim 6.3.0, released in March 2025, so hopefully Obsidian upgrades to the latest codemirror-vim soon!
