Incorrect TeX expression in quote block breaks indexing
Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
  • We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
  • For Linux, we only accept bug reports that are reproducible with our Appimage or Snap package under Gnome or KDE.
  • Developer issues with the API should go here
  • Themes and Custom CSS issues should go here
  • Obsidian Clipper Bugs should be posted here
  • Obsidian Importer Bugs should be posted here
This works
## heading 1
>$$ expr
## heading 2
i.e. the following block finds both headings
[[# heading ]]
This breaks the second heading
> $$ expr
since the entire expression is rendered as part of the quote block, the tex expression should be contained in the quote block even if it’s on a line without explicit quote prefix (“>”)
Rendering works, but indexing breaks silently.
Obsidian version: v1.8.1
Installer version: v1.7.6
Operating system: Darwin Kernel Version 24.3.0: Tue Dec 17 23:24:24 PST 2024; root:xnu-11215.80.28.501.2~1/RELEASE_ARM64_T6000 24.3.0
Catalyst license: vip
Insider build toggle: on
This is a silent functionality breaking that’s hard to find and debug
We are not going to support this.
The only syntax we support for math blocks we support is
$$math$$
OR
math
and for quotations
> $$math$$
OR
> math
The docs will be updated to reflect this.
Thanks for clarifying.
I think that’s ok, however the problem is indexing silently fails and the bug is that it actually renders correctly / doesn’t display an error.
If rendering works accidentally, although it shouldn’t, why don’t you then break the TeX rendering (and / or display an error)?
It should work consistently to how an open code block (```) renders all remaining text as code.
