Inconsistent syntax highlighting in code blocks in live-preview
Write code block (with ``` or ~~~) with a designated programming language and see the difference when:
- Written inline (no nesting)
- Nested inside a callout
- In reading mode
Yes
Syntax highlighting should be consistent across all contexts, matching the colors displayed in reading mode or inside a callout.
Syntax highlighting behaves inconsistently in live preview: fewer color variations are displayed compared to reading mode.
Interestingly, code blocks nested inside a callout render correctly, matching reading mode colors.
Obsidian version: 1.12.7
Installer version: 1.8.4
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:31:09 PDT 2026; root:xnu-12377.101.15\~1/RELEASE_ARM64_T8132 25.4.0
Language: fr
The editor (source mode / live preview) has different highlighting than reading view.
https://obsidian.md/help/syntax#Code
Callouts are considered “rendered” so anything within a callout, including a code block, is going to look like it would in reading view, even if viewing the note in live preview.
