  1. Create a new note (A) and input
	\DeclareMathOperator{\cov}{cov}
	\DeclareMathOperator{\var}{var}
	\newcommand{\E}{\mathbb E}
  1. Create a second note (B) and input
    $$\cov(X,Y) = E((X-\E X)(Y-\E Y))$$
  2. Restart Obisidian and open note B without first opening note A
  3. Switch to preview mode. Result:
  4. Now preview note A and then switch back to preview note B. Result:
Comment
Although this is not a bug per se, it seems like inconsistent behavior to me.
It is obviously caused by the fact that Obsidian uses a global Mathjax interpreter. If Mathjax first interprets the definitions in note A, it then understands how to display note B.
I would, in fact, like some consistent version of this behavior. For example, Neuron uses a head.html file that is included in every note. You can place your Latex header definitions in there. Is there anything like this for Obsidian at this point? I don’t want to copy all my definitions for math notes to every single note.
  • Obsidian version: v0.12.15
this is not a bug. there is a plugin that adds a shared macro to all files.
Understood. I just thought that notes causing side-effects to other unrelated notes may be considered a bug. Feel free to close this. What is this plugin called please?
Got it. Extended MathJax
