Write the following in a new page:
```ruby
arr = [1,2,3]
def foo(var)
puts var.size
end
```yml
# docker-compose.yaml
version: '3'
version2: 3
services:
mypostgres: # name
image: 'posgres'
image2: posgres
ports:
- 5438:5432
# - 5432:5432 -
environment:
POSTGRES_PASSWORD: db_pass
POSTGRES_USER: db_user
- POSTGRES_DB=db_name
volumes:
- db-data:/var/lib/postgresql/data # check where psql stores data
volumes:
db-data:
driver: local
Then toggle edit mode and view mode:
That both view mode and edit mode will show a consistent good syntax highlight,
for both ruby and yaml (and other programming languages as well)
Good Ruby highlight? Only in edit mode
Good Yaml highlight? Only in view mode
Can’t I have both?
At least make it so the view mode has both good ruby and yaml syntax
so I won’t be force to switch all the time.
The Ruby block highlight only works in edit mode
The Yml block highlight only work in view mode
Can’t have both ruby and yml show a good syntax highlight in same mode
- Operating system:
Runningpop os 22:04which is Ubuntu based
cat /etc/*release
DISTRIB_ID=Pop
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Pop!_OS 22.04 LTS"
NAME="Pop!_OS"
VERSION="22.04 LTS"
ID=pop
ID_LIKE="ubuntu debian"
PRETTY_NAME="Pop!_OS 22.04 LTS"
VERSION_ID="22.04"
HOME_URL="https://pop.system76.com"
SUPPORT_URL="https://support.system76.com"
BUG_REPORT_URL="https://github.com/pop-os/pop/issues"
PRIVACY_POLICY_URL="https://system76.com/privacy"
VERSION_CODENAME=jammy
UBUNTU_CODENAME=jammy
LOGO=distributor-logo-pop-os
- Debug info:
Obsidian version: v1.1.16
Installer version: v1.1.16
Operating system: #202212290932~1674139725~22.04~ca93ccf SMP PREEMPT_DYNAMIC Thu J 6.0.12-76060006-generic
Legacy editor: off
Plugins installed: 2
Plugins enabled: 2
1: Advanced Tables v0.18.1
2: Excalidraw v1.8.14
Edit mode: good ruby highlight but bad yaml highlight
View mode: good yaml highlight but bad ruby highlight:
