Inconsistent behaviour for implicit links
Create a note with the following content (without the triple backticks):
- Preventing linking.
  - Words with a period inside them are interpreted to be a link like example.com
  - but you can prevent this by embedded them in html like <span>example.com</span>.
  - Except this seems buggy in that if a list item has an implicit link like example.com , then the trick no longer works <span>example.com</span> even with the html tags.
I expect all instances of example.org not surrounded in <span> tags to be implicitly converted to links, but all instances of <span>example.org</span> to not be converted into links.
This works for the first two list items, but in the term list item, it seems that if the list item contains an implicit link in it, then the <span> trick for preventing interpreting a word with a period in it as a link, no longer works.
  • Obsidian version: v0.7.3
Possibly related to:
Tested in 0.7.4, issue still occurs here.
This has been fixed.
