In vim mode, "o" and "O" fail to insert newlines in HTML-style comments
Activate vim. Paste in the following snippet:
first. works ok
second. works ok <!-- comment -->
third. works ok
<!-- comment -->
fourth. `o` doesn't work, but `O` does <!--
comment -->
<!-- comment
--> fifth. `O` doesn't work, but `o` does
<!-- comment
--> sixth. neither `o` nor `O` work <!--
comment -->
Enter vim’s normal mode. For each line, try to use o and O.
Did you follow the troubleshooting guide? [Y/N] Y
When pressing o, a new line should be created below the current line, the cursor should jump to the start of that line, and vim should enter insert mode.
Also, when pressing O, a new line should be created above the current line, the cursor should jump to the start of that line, and vim should enter insert mode.
When pressing o on a line which ends partway through a multi-line HTML comment, the cursor jumps to the end of the current line without inserting a new line, and vim doesn’t enter insert mode.
When pressing O on a line which begins partway through a multi-line HTML comment, the cursor jumps to the end of the previous line without creating a new line, and vim doesn’t enter insert mode.
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: Windows 10 Home 10.0.19045
Legacy editor: off
