In settings, provide number of enabled plugins alongside number of plugins installed
The Community Plugins section of the settings menu indicates how many plugins you have installed. However, a statistic just as relevant (and, I would argue, often more relevant) is how many are currently active/enabled.
It seems like it would be trivial to add the enabled count to the following section of the Community Plugins menu:
In this case, it would instead read “You currently have 29 plugins installed (15 enabled).”
The number can be obtained by pulling up the debug info.
:+1: just giving my vote. Also that information should be presented more clearly: I didn’t even know it was available. It should be located at the top with some emphasis like different colored font (probably accent color).
