In live preview, how to make images side by side and clickable link or add a clickable link?
I’m trying to move away from Dokuwiki, but there are certain key features that I need to replicate before I do so. One of which is clickable image links or at least a caption that can link to internal notes. Course, another feature is wiki style infoboxes, but I’ll save that for later.
Basically I’m trying to make, when you click on an image, it goes to an internal note. Or at least a way to add a caption that is clickable. I’ve been trying, but nothing seems to work. And they must be able to be side by side.
This must work in live preview, I don’t use read mode.
The only work around that I’ve found was to use tables, but it doesn’t look that good and, as far as I’m aware of, there’s no way to color in other rows, not just the top row. Then the title above the image is the link. This doesn’t look as good, but it’s the only thing I found so far that’s passable at least.
Some info about this here:
Dataview implementation (not quite what you want):
