- Disable `Settings:Editor:Behavior>Indent using tabs"
- Set
Settings>Editor:Behavior>Tab indent sizeto 2 spaces. - Open a new document/page
- Enable edit mode
- Type many nested list items. e.g
- test - test - test - test - test - Observe that the rendering is inconsistent. If one simply hits enter at the end of the line, and then tab to indent, the following is the result:
8. If you reload Obsidian, it then looks like this:
Y
I would expect to see nested lists rendered as follows:
- test
- test
- test
- test
- test
They are instead rendered like this:
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: #1 SMP PREEMPT_DYNAMIC Tue, 10 Sep 2024 14:57:31 +0000 6.6.50-2-lts
Plugins installed: 7
Plugins enabled: 5
1: Chesser v0.2.1
2: Tag Wrangler v0.6.1
3: Latex Suite v1.9.5
4: Advanced Tables v0.22.0
5: Templater v2.7.1
None.
