I am trying to import obsidian notes from Notion.
I used Import from Notion - Obsidian Help as a manual.
As mentioned in Import from Notion - Obsidian Help,
I exported from Notion in html - filled .zip,
with Include subpages
and Create folders for subpages
The zip file has another nested zip-file, so I unzipped the outer one, as directed by the same manual.
The inner zip-file is 9.37GB.
Looking inside, it has subfolders for each page and is containing html files.
I tried to import it with importer
As manual, I disabled all other community plugins than importer
, reloaded Obsidian, and used importer
to import it.
Here are the results;
Others to mention
- I use Hangul (Korean alphabet).
- Strangely, when I try
Output folder
other than the nameNotion
or blank, it halts (freezes). - I use Megasync as a tool between computers. But even if I remove all in
trash
folder, or exit the Megasync program, the problem remains. - The zip file looks like this (opened in Bandizip)
I am looking forward to your assistance. Thank you!
