Import files from ConnectedText - help with regex
I’m trying to find out if it is possible to convert the ‘categories’ produced in .txt note exports from the old app ConnectedText to Obsidian ‘tag’ formatting.
I need to change lines that look like the following;
[[$CATEGORY:apples|oranges|orangutans]]
Into obsidian syntax, i.e.;
#apples
#oranges
#orangutans
I’m assuming I need to use some kind of batch regex find and replace on all the files, but I don’t know how to do it. Can anyone help? Or is there a better way?
I’ve searched the forums and can see that several former ConnectedText users have imported their notes into Obsidian, but I can’t find any info about how they have done it.
I think I have managed to work this out. My approach;
First, run a regex find and replace with the following terms
Find:
(^[[$CATEGORY:)(.+)(]]$)
Replace:
|$2
This turns
into
It is then possible to run a normal find and replace, to turn all the pipes into a space followed by a hashtag.
Happily, ConnectedText has a global find and replace function within the software, so I think I should be sorted.
