Right now the “toggle comment” shortcut only adds %%%% style comments, which are incompatible with most other markdown editors I’m aware of, and are not compatible with the markdown processor I’m using to generate html for my website.
It would be very useful to have an option to use the standard HTML-style comments instead.
Having a shortcut for that would make a big difference, because when you need to use comments often (as I do), typing them every time is a pain in the ass.
I second this request. HTML-style comments are widely supported in other markdown editors and tools whereas Obsidian’s %%%%-style comments are pretty exotic.
I think it would probably be best to not implement HTML comments as a separate command but to include a setting for choosing between the two styles (e.g., like the “Use [[Wikilinks]]” setting). I would be happy with either solution though.
For me that would also be great, I’m currently also having a use case where I’m writting the draft in Obsidian and later dynamically import the markdown and render it as the “website’s” content.
I have the habit of using comments to note what I want to say, so this adds some additional pain points when moving the text from obsidian to the different markdown processors.
(“website” is in quotes because I’m actually working on my job application documents and I’m creating those with webdev tech. In this case the “drafts” are for the text of cover letters)
edit: saw that there is a plugin called better comment toggle that can create html comments, so that is an alternative for now. But I think this would be a valuable feature to have implementated as part of Obsidian itself.
