Imgur Plugin does not work
Help me, I uploaded images onto Imgur using the Imgur Plugin and currently encounter the below issue:
<!--⚠️Imgur upload failed, check dev console-->
My console is shown as below
What should I do to fix it?
Things I tried and nothing worked.
  • Uninstalled and Reinstalled the Imgur Plugin
  • Clear all caches in relation to Imgur on my web browser and login the Imgur
  • Create new clientid and tried to use it in the Imgur Plugin
I would check the plugin’s GitHub issues page to see if anything similar turns up.
