Images not being synced with headless obsidian
On Windows desktop Obsidian (latest version), create a new note called:
sync-test.md
Paste an image into the note using clipboard paste.
This generates:
![[Pasted image 20260303233404.png]]
Confirm the image file exists physically inside the vault directory:
C:\Users\Documents\Obsidian Vault
(File size ~100 KB)
Wait for Obsidian Sync on desktop to complete.
On Linux server running headless client:
cd /opt/obsidian-vault
ob sync
Search for the image file:
find /opt/obsidian-vault -name “Pasted image 20260303233404.png”
Result:
No results.
The markdown file syncs, but the image attachment does not.
Did you follow the troubleshooting guide? [Y/N] Yes
After running:
ob sync
The image attachment file should appear somewhere inside:
/opt/obsidian-vault
Markdown note syncs successfully.
PDF attachments sync successfully.
Image attachments do not download to the headless vault.
Server:
Linux
Headless Obsidian Sync client (ob)
Vault path: /opt/obsidian-vault
Desktop:
Windows
Latest Obsidian version
Vault path: C:\Users\Documents\Obsidian Vault
ob sync-config:
Vault: Default Vault (…)
Sync mode: bidirectional
Conflict strategy: merge
File types: image, audio, pdf, video
Configs: none
The same vault syncs correctly between multiple desktop devices, including image attachments.
Issue appears specific to the headless ob client.
Reproducible with a brand-new test note and newly pasted image.
Which version of obsidian are you using and which version of obsidian headless are you using?
on my windows 1.12.4
on my phone same (299)
Headless 0.0.5
Fixed in v0.0.6.
This was caused by the default file types to print that it syncs images and other things, but in fact it was actually an empty list so it only synced markdown.
