I’m not using synchronization.
Suddenly, I lost my laptop so I bought new laptop.
I tried to check the obsidian note on my new laptop, but I couldn’t check the note
I bought obsidian sync for 10$
But I keep trying to find it, but it doesn’t sync
It sounds like you also didn’t backup the files on your prior laptop? If you weren’t syncing and didn’t backup, then the notes only exist on the lost laptop. If you bought Sync after losing the laptop, it won’t help you get your notes back.
