Ignore or prevent linking in code blocks
A dialog box keeps popping up when I’m typing in this code block. The dialog box bafflingly says “No match found” and below that has 3 sections saying “Type # to link heading”, “Type ^ to link blocks” and “Type | to change display text”.
I was working on this bit of example code when I stumbled across it. Paste it into an empty note in the sandbox vault to reproduce reliably.
(def data [[1,2], [3,4]])
(let [[[a b]] data] (println b)) ; 2
(def greeting "Hello, world!")
(let [[ _ _ _ _ _ _ _ name ] greeting] (println (apply str name)))
Moving the cursor after name and adding a space will make the dialog pop up.
(Incidentally, the above code doesn’t work, inserting a & before name captures the tail. But this was the state of the code when the dialog box started bugging me.)
I would keep typing without a dialog box getting in my way.
Dialog pops up if I type or even delete anything in that section of the code. It make it difficult to edit and copy/paste when I’m experimenting with the code examples.
  • Operating system: Linux
  • Debug info:
    Obsidian version: v1.1.9
    Installer version: v1.1.9
    Operating system: #1 SMP PREEMPT_DYNAMIC Thu Jan 12 20:29:03 UTC 2023 6.1.5-229.current
    Legacy editor: off
I assume what’s happening is all the weird surrounding syntax and square brackets is confusing the Obsidian’s helper for markdown link creation. I would probably disable this helper inside of code blocks to avoid this situation. It will come up a lot with certain languages, to say nothing of code blocks containing actual markdown.
Screenshot from 2023-01-30 01-04-17
Simpler example code.
[[ anything ]]
Pretty much anything between two square brackets will cause the issue. Adding characters. Spaces. Deleting things.
It had been going on for a while and I barely noticed but when it started popping over other parts of my code it became a nuisance.
This is a bigger problem than just wikilinks.
Either this Make Obsidian's behavior on codeblocks dependant on their type or since now we have callouts, threat all code blocks as code-containing.
Interesting, thanks!
Is there a way to disable this feature for all code blocks in the meantime?
Not at the moment, sorry.
It might be possible to build a plugin to support such a toggle.
